Date/Time: Fri, 28 Feb 2025 09:12:32 +0000
Volume profile and numbers on Daily Historical chart
View Count: 681
[2021-08-11 19:12:42]
balkis6 - Posts: 4
I really need volume numbers on Daily Historical chart.
Is that possible as now I get 0x0 for volume on each Daily candle as in an attached file?
Any work around or smth?
imageno_volume.png / V - Attached On 2021-08-11 19:12:03 UTC - Size: 28.88 KB - 211 views
[2021-08-11 19:22:58]
John - SC Support - Posts: 38259
When you are looking at Daily Historical Data, you are looking at the daily information that is provided by the exchange, which does NOT include any individual pricing volume information. It is just the Open/High/Low/Close and Volume for the day.
Therefore, to do what you want, you would need to use the Intraday data. To do this, you need to set Chart >> Chart Settings >> Chart Data Type to Intraday Chart Only. Refer to the following:
Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu)
