Date/Time: Fri, 28 Feb 2025 09:13:01 +0000
how to build a yield differential
View Count: 420
[2021-08-11 18:48:56] |
mrseho - Posts: 25 |
Hi, do you have a study where I can build a yield differential. I would like to substract the ZT future from the ZN future and then flip it horizontally. Thx Sebastian
[2021-08-11 19:16:45] |
John - SC Support - Posts: 38259 |
Refer to the following to subtract the symbols: Custom Calculated Symbols And refer to the following to invert the data: Chart Settings: Invert Prices (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
