Date/Time: Fri, 28 Feb 2025 09:47:08 +0000
Switching from Simulation account to live account
View Count: 572
[2021-08-11 16:10:22]
gretat - Posts: 11
I have been trading in the enhanced simulation, and I am unsure how to get to trading live. The trade simulation menu item cannot be changed to off.
[2021-08-11 16:31:08]
John - SC Support - Posts: 38259
You are using our Trading Evaluator, therefore you would need to switch to your Trading Service in the File >> Data/Trade Service Settings.
If you are not familiar with how to do this, then let us know what trading service you use and we will link you to the Setup Instructions.
[2021-08-11 17:27:48]
gretat - Posts: 11
Thank you - I am using Gain capital if you could give me those setup instructions
[2021-08-11 17:54:44]
Actually, we do not have instructions for Gain Capital. But all you need to do is to open the Data/Trade Service Settings Window by selecting File >> Data/Trade Service Settings, then in the Current Selected Service select Gain Capital/OEC. Then select the A button to the right of that entry to apply that change. You will then see the items below change for additional items you need to enter.
Enter the information in those new fields as needed. Then select OK to close that window. You are then done.
