Date/Time: Sun, 27 Sep 2026 08:58:34 +0000
Delayed data Denali
View Count: 872
| [2021-08-11 16:09:01] |
| user777 - Posts: 8 |
I signed up with amp yesterday and made a deposit. I can connect to data but is delayed by 10 minutes. I contacted Amp and they said contact SC
| [2021-08-11 16:28:18] |
| John - SC Support - Posts: 48028 |
Everything looks good on your account at this time. If you are still getting delayed data for a symbol that is traded on the CME Group, then check to ensure that the setting File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. Refer to the following: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) If that is not the issue, then we would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
