Date/Time: Fri, 28 Feb 2025 09:28:37 +0000
Attached Orders: How to Move to Break-Even Plus 2 Ticks After 20 Ticks in Profit
View Count: 1405
[2021-08-11 13:59:16]
User94606 - Posts: 327
Using the Attached Orders, how do I setup moving the position to break-even plus 2 ticks only after 20 ticks in profit automatically?
[2021-08-11 15:43:43]
ForgivingComputers.com - Posts: 1015
In the Trade Window, select the Targets Tab, if there is no Stop click Add. Adjust the Stop Offset to the initial amount. Select Stop if not already selected. In the Move to Break Even section, click Step 1, and in the Type: dropdown, select Offset in Ticks Triggered, then set BE Level offset to 2, and the Trigger Offset to 20.
[2021-08-11 16:58:36]
Thank you Brath.
[2021-08-12 01:12:40]
Is there a way to add additional buttons to the Trade Window? I would like to add new buttons such as Break-Even+2 Ticks button, etc..
[2021-08-12 01:40:59]
No, but ACS Control Bar buttons can work with a custom study to do those things.
[2021-08-12 02:13:02]
Do you need to know ACSIL in order to configure ACS Control Bar buttons?
[2021-08-12 12:45:31]
Not all Control Bar Buttons are ACS buttons. There are many things you can do with the buttons without ACSIL. For example, you can add buttons to move the stop up or down by one tick. Global Settings>>Customize Control Bars>>Control Bar x The menu on the left has a very extensive list of many menu commands.
More complex interactions, like "Close Out 50% of the Position", do require the use of ACSIL to configure the ACS Control Bar buttons. I have developed tools for clients doing complex commands like this. Please Direct Message me if you would like to know more.
[2021-08-12 20:06:53]
Thanks Brath. Let me take a look at the ACS bar buttons and let you know
Date Time Of Last Edit: 2021-08-12 20:09:18
