Date/Time: Fri, 28 Feb 2025 04:58:50 +0000
trading d'option
View Count: 434
[2021-08-11 11:42:49] |
User358237 - Posts: 3 |
Bonjour, je souhaite trader les options et j'aurais aimé savoir si sierra chart propose un module option (chaine d'option et pricer)afin de pouvoir gérer cela? Si oui, ou se trouve le module dans sierra? Merci |
[2021-08-11 14:26:39] |
John - SC Support - Posts: 38259 |
From Google Translate: Hello, I want to trade options and I would have liked to know if sierra chart offers an option module (option chain and pricer) in order to be able to manage this? If so, where is the module located in sierra? Thank you Options are available within Sierra Chart, but we do not have the Option Chain display. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
