Date/Time: Fri, 25 Sep 2026 10:19:58 +0000
Default Settings for Chart Drawing Alert Box?
View Count: 951
| [2021-08-11 02:00:19] |
| The Stealthy Trader - Posts: 190 |
I draw a lot of Lines on Charts during the course of a day. Additionally I set Alerts for those Lines. However it seems like have to select the same options inside the Alert Box each time..like "Crosses" "Last" "Alert Sound"..etc..etc It would be great if I could right click on a line I just drew, choose Alert and then the box opens with my default choices for the 7 or so options within the box instead of them resetting to a different default all the time.. Is this possible? TIA |
| [2021-08-11 06:08:24] |
Yes you can configure the default Alert Settings with the default tool configuration for a particular drawing tool and configuration number: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-11 13:20:56] |
I do have an additional question..How do I set it so after utilizing any Tool, like Line, it resets to my default Tool, Hand? Presently I draw a Line and then move on and my next interaction with any chart results in another Line being drawn..causes me to have to take time to delete unnecessary lines. Presently I click on Hand icon in toolbar, which I never remember to do, but even that is an added step.. TIA Date Time Of Last Edit: 2021-08-11 13:22:00
| [2021-08-11 14:32:42] |
| John - SC Support - Posts: 48003 |
Refer to this setting: Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-11 14:40:11] |
wow, I would never have found that..thanks again..
