Date/Time: Fri, 28 Feb 2025 03:59:38 +0000
I have tried everything
View Count: 553
[2021-08-10 19:03:53] |
Manerva Funding Financial - Posts: 16 |
I am not sure what I am missing. However I have tried everything to turn the TPO to letters vs the bars. Is there something I can do to change it? Also I have attached a chartbook I would like to replicate. How do you get the volume on the TPO chart https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53617 |
[2021-08-10 19:17:52] |
John - SC Support - Posts: 38259 |
To set the TPO as letters, you change this Input: Time Price Opportunity (TPO) Profile Charts: Sub Period Price Display Style To get the Volume as displayed in the image you provided, you need to add a Volume by Price study. When you add a VbP to a chart with a TPO already on it, then the VbP is automatically setup to match the time frame of the TPOs. You would then just need to display the Volume in the VbP using this Input: Volume By Price Study: Display Volume in Bars Also refer to the following regarding displaying a Volume by Price profile with the TPO profile: Time Price Opportunity (TPO) Profile Charts: Displaying Volume Profiles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
