Date/Time: Fri, 28 Feb 2025 04:56:40 +0000
Ninjatrader brokerage
View Count: 900
[2021-08-10 18:13:01] |
OX - Posts: 7 |
I am currently using Ninjatrader and their brokerage. What would be the easiest thing for me to do to switch to Sierra. Change brokers or stay with ninja? Is that possible to just keep Ninja broker and use sierra? What kind of monthly costs would I be looking at for either route? I want to use the Advanced 11 data feed |
[2021-08-10 18:26:49] |
John - SC Support - Posts: 38259 |
Start by referring to the information here: Using Sierra Chart with Ninja Trader Brokerage Once you know whether you are using CQG or Rithmic with NinjaTrader, then you would follow the appropriate instructions to setup your Sierra Chart to that order routing service. For Rithmic, refer to the Setup Instructions here: Rithmic Trading Platform Service For CQG, refer to the Setup Instructions here: CQG Trading Platform Service: Setup Instructions And then, in order to use the Denali Exchange Data Feed for data from the CME Group, you will follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you want data from EUREX, or CFE, then those instructions are on the same page as the CME Group, just scroll to the top of the page and find the link for the exchange you want and follow these instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-11 01:51:24] |
OX - Posts: 7 |
I activated my cqg data feed on sierra. Once my free trial is done on the 17th do I need to purchase the advanced service package 5 in order to use the platform?
[2021-08-11 11:27:53] |
Sierra_Chart Engineering - Posts: 18594 |
Yes that is correct.
