Date/Time: Fri, 28 Feb 2025 04:57:39 +0000
Setting SC for uProfit trading eval.
View Count: 1016
[2021-08-10 14:54:08]
User715828 - Posts: 61
Hi, I am going to do a uProfit trading eval. My live account is through AMP, I am using your Denali feed and CQG order routing. uProfit uses the Rithmic feed. I want to also trade live. Can I make my SC platform access the uProfit trading eval as well as have the option to trade my live account? If possible, can you please provide instructions on how to do this. Thank you
[2021-08-10 16:11:28]
John - SC Support - Posts: 38259
The best way to do this is to use a second installation of Sierra Chart and setup that second installation to connect to the uProfit Rithmic server while keeping your first installation connected to AMP. This will also allow you to continue to use the Denali Exchange Data Feed in both installations. There are no additional fees for this setup.
Refer to the information at the following link for how to install another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
