Date/Time: Fri, 28 Feb 2025 05:03:36 +0000
[Programming Help] - Tools (Time Projection/Expansion)
View Count: 527
[2021-08-10 10:39:44]
User92573 - Posts: 547
Dear Support
Please would you consider making some changes/enhancements to both the Time projection and Time Expansion Tool.
At present the Standard, Compress and Extend are fine for presentation of the ratio lines but when using compress or standard it is very difficult to "move" the "ratio lines" vertically to the required position as the:
Time End (Time Expansion Tool)
Proj. Start (Time Projection Tool)
Also moves away from the selected time point making alignment very difficult.
Ideally on Create, or Adjust, the Anchor/s and Projection Point should be fully extended vertically irrespective of any other show/hide/level settings. This would allow proper placement/adjustment of the final line even when using the standard/compressed and any other show/hide settings are employed.
As always, I'd be happy to contribute to the cost of the enhancement. Please would you initially confirm the cost and the timeframe.
Many thanks
