Date/Time: Fri, 28 Feb 2025 08:55:56 +0000
reply chart dom price not matching with chart
View Count: 501
[2021-08-10 09:23:34]
User945742 - Posts: 12
Hi
I have loaded historical data from iqfeed, however DOM price not matching with chart while replying (it's showing current price guess), any settings I need to check?
[2021-08-10 11:58:05]
Be sure to follow the instructions here regarding this:
Replaying Charts: Replaying Trade DOM Windows
Date Time Of Last Edit: 2021-08-10 11:58:19
[2021-08-11 12:43:46]
working with by time not by next bar on initial checks, any reason?
[2021-08-11 14:29:46]
John - SC Support - Posts: 38259
We do not understand the question here. Please give us more information.
[2021-08-11 15:14:16]
actually trying to backtest, while replaying chart and going backwards; unwanted active orders showing. I am not sure why. Going
forward with backtest no issues
[2021-08-11 15:18:29]
here is a snapshot, not sure what's happening, if you see the bigger ticks there like +50 those are not my order.
imageCapture.JPG / V - Attached On 2021-08-11 15:18:17 UTC - Size: 250.8 KB - 178 views
[2021-08-12 05:22:02]
You cannot jump back in time when back testing, it will cause issues.
[2021-08-12 07:09:17]
what's the recommended way to go back then so that backtest data not impacted?
[2021-08-12 13:57:35]
If you are running a "Backtest", then you can not go backwards.
If you want to go back to rerun something during the process, then you would need to do that while using one of the Replay options, just not when doing a "Backtest". Refer to the following:
Replaying Charts
[2021-08-13 16:30:22]
You need to use a different Trade Account:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
