Date/Time: Fri, 28 Feb 2025 04:37:40 +0000
Is it possible to AUTO ADJUST the tick chart base on a certain study ?
View Count: 581
[2021-08-09 22:13:54]
GravisHTG - Posts: 306
I am asking because I am day trading equities and As I change stock a lot during the day, I have to readjust the T-chart all the time.
thanks
[2021-08-10 13:30:15]
John - SC Support - Posts: 38259
The Right-Side Price Scale is always going to use the Main Price Graph (bars) for determining the scale. But, any other study that is set to "Automatic" will also be taken into consideration for the scaling. So if you have a study that you want to be included in the scale adjustment, just make sure that it is set to "Automatic". For more information, refer to the following:
Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region
