Date/Time: Fri, 28 Feb 2025 04:57:39 +0000
Trading disabled in AMP
View Count: 580
[2021-08-09 21:24:02] |
MichalG - Posts: 6 |
Hello, I have just refilled my account after some break and needed to update my data feeds. I needed to reactivate my AMP account. When I select CQG in Sierra it states that the symbol is not allowed (SE, NQ). When I change to "SC data all services" data is working but I can only have simulated transactions, data is delayed. What should I do to have it done correctly and make market transactions? Thanks, Michal |
[2021-08-09 22:11:02] |
You need to contact your broker for help with CQG connectivity issues. For market data we do recommend using the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
