Date/Time: Thu, 17 Sep 2026 20:01:50 +0000
Multi Accounts
View Count: 659
[2021-08-09 17:04:49]
User460426 - Posts: 6
Hey,
i would like to have two trading accounts on my account.
Unfortunately, my broker does not provide me with a level 2 data feed.
How can I make it so that one account provides me with the data feed and I use the other account for trading?
Best regards
Christian
[2021-08-09 17:40:25]
John - SC Support - Posts: 47930
We are really not understanding what exactly you want to do.
If you are not getting the data you need from your broker, particularly with regards to Market Depth Data, then you can just use the one of our data feeds which does include this information. You can use our data feed in combination with your trading account, as this is how Sierra Chart is setup. Refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
If you are asking about having multiple trading accounts, then this is also not a problem as long as they are both under the same login with your trading service. In this case, both accounts will show up in Sierra Chart and you can select the particular account you want to trade with from the Trading Window. Refer to the following:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
If we have not answered your question, then please give us more information on what exactly you are wanting to accomplish and we will give you the best way to do it.
