Date/Time: Mon, 25 Nov 2024 22:33:24 +0000
Yen not updating - OEC
View Count: 1127
[2014-03-20 15:46:03] |
User70416 - Posts: 19 |
My Yen, 6JM4, is not updating. No current info. I understand you are working on other OEC problems. I have read other posts on this but nothing helps. |
[2014-03-20 17:10:23] |
NRGTrader - Posts: 351 |
Not just 6JM4 that isn't updating
[2014-03-21 09:45:49] |
This is now resolved. Refer to: OEC Currency Futures Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
