Date/Time: Fri, 28 Feb 2025 04:00:34 +0000
I can´t connect with Rithmic
View Count: 352
[2021-08-09 16:15:20] |
User273159 - Posts: 1 |
Rithmic Trading | Port for executable: 56453 | 2021-08-09 16:24:12.679 Listening socket (1992). Port 56453 | Closed. | 2021-08-09 16:24:12.679 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2021-08-09 16:24:12.679 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2021-08-09 16:24:12.701 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2021-08-09 16:24:13.415 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-08-09 16:24:13.415 DTC Client socket (1) | Closed. | 2021-08-09 16:24:13.415 Rithmic Trading | Bridge process is not running! | 2021-08-09 16:24:14.693 Rithmic Trading | Connecting to the server 127.0.0.1. Port 56453 | 2021-08-09 16:24:14.693 DTC Client socket (1) | Creating socket. | 2021-08-09 16:24:14.693 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-08-09 16:24:14.694 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-08-09 16:24:14.694 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2021-08-09 16:24:16.745 * DTC Client socket (1) | CloseSocket call. | 2021-08-09 16:24:16.747 DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-08-09 16:24:16.747 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-08-09 16:24:16.748 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-09 16:24:16.748 DTC Client socket (1) | Closed. | 2021-08-09 16:24:16.748 DTC Client socket (0) | CloseSocket call. | 2021-08-09 16:24:16.780 Rithmic Trading | Disconnected. | 2021-08-09 16:24:16.780 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-08-09 16:24:16.780 |
[2021-08-09 16:45:14] |
John - SC Support - Posts: 38259 |
From what we have seen, the old Bridge connection is no longer working with Rithmic. There is a new interface available. to use this new method follow these Setup Instructions: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
