Date/Time: Fri, 28 Feb 2025 04:53:11 +0000
Data for XAVU21-CME Healthcare Future not availlable
View Count: 384
[2021-08-09 16:15:00] |
mrseho - Posts: 25 |
Hi, I have a chart with all sector futures running. Today I discovered that the Healthcare future disappeared from the selection in your data feed. Could you please help me, to get this fixed. Thx, Sebastian
[2021-08-09 20:31:05] |
Sierra_Chart Engineering - Posts: 18594 |
This is resolved. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
