Date/Time: Fri, 28 Feb 2025 04:37:52 +0000
I can not open the chart
View Count: 496
[2021-08-08 04:03:40]
User657856 - Posts: 61
I was able to login using my old password.
But I waste a lot of time to do that and i could not play that day.
Sincerely
[2021-08-08 09:50:18]
We did have a problem with this on Friday for Transact users but this was resolved at that time. So you should not have a problem logging into Sierra Chart as a Transact user.
Additionally:
We have reset your Sierra Chart charting and trading software password. It has been sent in a separate e-mail to your e-mail address.
If you did not receive it, let us know. Your e-mail provider may have filtered the message and placed it in a junk mail folder.
For complete Login instructions and help with possible Login problems, refer to:
Sierra Chart - Software Login Instructions
If you continue to have a problem logging in, then let us know and provide us with the *exact* error message you see after pressing the Login button.
