Date/Time: Fri, 28 Feb 2025 04:38:53 +0000
Draw Volume Profile Tool - Setting changes can´t be saved as default.
View Count: 1027
[2021-08-07 12:01:12]
User355493 - Posts: 27
if i use/draw the "Draw Volume Profile" function in a chart and if i change the settings via "Study Settings --> VbP (settings) --> ln:43 changed --> click on "Set Defaults" will not be saved. The next drawing has the old settings. Saving of these settings doesn´t work.
What´s the Problem ?
Or how can I reset the setting of the tool to the original state as it is the case with a "new installation of Sierra Chart" - without a complete reinstallation of Sierra ?
Thanks for your help.
Best Regards
imageDrawVolumeProfileTool.PNG / V - Attached On 2021-08-07 12:00:41 UTC - Size: 83.74 KB - 237 views
[2021-08-07 13:02:27]
User907968 - Posts: 833
DVP tool uses 'tool configuration' to determine how VBP is drawn, detailed instructions for configuring DVP tool can be found here - Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
[2021-08-07 17:43:10]
Yes refer to:
