Date/Time: Fri, 28 Feb 2025 04:17:35 +0000
CHANGING TIME AND SALES COLORS does not worl
View Count: 540
[2021-08-06 16:59:24]
MR17 - Posts: 34
hi !
i am customizing my times and sales so i went on
chart --> graphic setting
and when i change the colors of any item for time and sales features, nothing is changing on my time and sales window and i checked the 'enable' button but nothing !!
i have the same trouble on my DOM when i want to color any of my DOM column
i don t understand
any tips ?
thanx
[2021-08-06 17:53:23]
John - SC Support - Posts: 38259
Typically when the graphics are not updating it means that you are either trying to change the Global Graphics when the chart is set to use the Chart Graphics, or the opposite (you are trying to change Chart Graphics when it is set to use Global Graphics). Refer to the following for information on the Global Graphics Settings versus Graphics Settings - Chart and when each is used:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
