Date/Time: Mon, 25 Nov 2024 22:43:42 +0000
having a problem with VAH VAL
View Count: 1164
[2014-03-20 13:33:21] |
User43469 - Posts: 3 |
i tried to close sieera and open again but won't help it gives me to a big range Shloimi |
ESM4 3 Min #1 41718.559.png / V - Attached On 2014-03-20 13:32:23 UTC - Size: 69.83 KB - 394 views |
[2014-03-20 15:51:19] |
The image you provided is too complex. Have a look at the Study Settings for the Value Area Lines study and see if they are correct based upon what you want to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-20 15:51:35
