Date/Time: Fri, 28 Feb 2025 04:02:17 +0000
can't login with my account name and pw
View Count: 584
[2021-08-06 03:37:08]
User38682 - Posts: 18
I'm having trouble logging in. I've logged in with these credentials hundreds of times why am I getting this now? jgvargas
Date Time Of Last Edit: 2021-08-06 05:37:44
[2021-08-06 13:57:58]
John - SC Support - Posts: 38259
We assume you have logged into the support board with an old name since you can't login with your current one. But, we do not see another account associated with the same email that the account you posted from has. So we can not look into the status of the other account, as we do not know what it is.
The only thing we can suggest is to reset your password. You can do this from the following page:
https://www.sierrachart.com/PasswordReset.php
[2021-08-06 15:46:52]
We are aware that certain accounts that use TransAct are having issues logging into Sierra Chart.
Can you please try logging in again, as we have made an update that we think will resolve this.
If not, then you will need to reset your Sierra Chart password on the following page:
Please let us know if you were able to login using your old password, or if you needed to reset it.
[2021-08-06 16:44:31]
SC Support - Posts: 1937
Spoke to User38682, helped him reset his Sierra Chart password.
