Date/Time: Fri, 28 Feb 2025 09:39:45 +0000
V2294 : positions not showing in QuoteBoard window
View Count: 476
[2021-08-05 18:44:48] |
User877753 - Posts: 152 |
Hello, V2292/2293/2294 Just noticed the positions do not show in the QuoteBoard window. Used to wwork until recently. Positions appear correctly in the 'Trade Positions' window. Thanks for your help, Regards JM |
[2021-08-05 19:22:04] |
John - SC Support - Posts: 38259 |
Is the Position field not showing, or are you not seeing the quantity of your positions listed in the Position field?
[2021-08-05 19:39:14] |
Not seeing the quantity of my positions listed in the Position field.
[2021-08-06 02:49:12] |
We will check on this. And resolve.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-06 02:49:19
[2021-08-06 16:36:30] |
We looked into this, and there is not an issue with this. What you need to do is open a chart . Select Trade >> Attach Trade Window to Chart. On the Trade Window select the account that contains the positions from the trade account drop-down list. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-06 17:45:19] |
Well, Trade Window and Trade Positions give the correct position. As I pointed, the position do NOT show up in the QuoteBoard window. It worked a couple of weeks ago. |
[2021-08-13 16:12:35] |
The Quote Board Positions depends upon the most recently selected Trade Account on the Trade Window. There is not a problem. We tested this. Refer to: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-13 16:13:34
