Date/Time: Fri, 28 Feb 2025 09:35:27 +0000
PNL Incorrect Display
View Count: 1027
[2021-08-05 16:03:51]
xyzeee - Posts: 8
Hi there,
1) My PNL is always incorrectly displaying all values as negative. I could profit 2pts and it would be -2. Even on losses it would still tally into a negative, so all profits and losses are tallied as negative. How can I go about fixing this? (eg: profit 2, loss 5, total -7)
Thanks in advance!
[2021-08-05 16:06:29]
xyzeee - Posts: 8
Now it's totally wonky and adding random values as well. Made a 2pt trade and a 0pt scratch and I'm at +10.5p for the day.
[2021-08-05 17:00:33]
John - SC Support - Posts: 38259
Refer to the following:
Help With Daily Profit/Loss Value
[2021-08-06 21:39:24]
xyzeee - Posts: 8
None of the things from the link helps. For some reason, it is reading all the values differently. I can make a 2pt trade and it will say that I've got some random number like 25pts. Whether positive or negative is a crapshoot. Another trade will just add on more random values and the entire duration of trading, it will be totally wrong and unusable.
[2021-08-09 13:39:03]
There is something wrong with your order fills from which the Daily P/L is derived. The only information we can provide is in the link we gave previously as this gives you the information you need to determine what is wrong/missing from your orders in order to correct it.
[2021-08-13 16:07:04]
This cannot be true at all. That documentation on the subject is very very thorough and precise assuming you are referring to the Daily Profit/Loss value within a chart. You should be able to precisely identify what the problem is.
Here is the documentation again:
Date Time Of Last Edit: 2021-08-13 16:08:08
