Date/Time: Fri, 28 Feb 2025 04:48:18 +0000
Can't have proper candle outline color
View Count: 659
[2021-08-05 15:54:27] |
BenjFlame - Posts: 335 |
Hi, I believe I set the number bars study to properly show and color candle outline as you can see in my settings. However, 100% of candle outlines are red, no matter if the candle is up. I also set: Global Settings >> Graphics Settings: Color Candlestick High-Low Using the Outline Colors Buy it doesn't help. How can I have up candle green outlined, and red for down candles? |
![]() Attachment Deleted. |
[2021-08-05 16:56:24] |
John - SC Support - Posts: 38259 |
What is your Chart >> Chart Settings >> Graph Draw Type set to? If it is Point and Figure, then that is the cause of the issue. You would need to change it to another option. Refer to the information here: Numbers Bars: Open and Close Marker Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 17:18:39] |
That was it thanks.
