Date/Time: Fri, 28 Feb 2025 04:50:40 +0000
Drawing from Tick chart to Time chart problem with premarket slow ticks
View Count: 352
[2021-08-05 14:59:42] |
GravisHTG - Posts: 306 |
When I draw Ray or anything on a tick chart when the market is way slower in a Tick chart ( like pre-market) The copy of that drawing in the 1 min chart is not equal because of how it copies between charts. The small Green is a GANN FAN and the tick green is a ray. Is it possible to fix this or its too difficult to do ? Thanks Date Time Of Last Edit: 2021-08-05 15:01:07
[2021-08-05 15:26:02] |
John - SC Support - Posts: 38259 |
Refer to the following for how the drawings are mapped between the two charts: Lines/Rays or Other Chart Drawings Move After Drawing Them: Chart Drawings Are Misaligned After Changing the Period / Timeframe Per Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
