Date/Time: Fri, 28 Feb 2025 05:00:59 +0000
wrong max open loss on SIM
View Count: 370
[2021-08-05 14:32:07] |
NotIll - Posts: 118 |
I think the titel says it all. this was on a big sweep against me that got me out above my stop loss. Are exits on these sweeps realistic at all? and how come its shows such a max open loss whilst the charts and fills say otherwise?
Date Time Of Last Edit: 2021-08-05 14:32:40
[2021-08-06 08:18:06] |
We are not understanding what you are trying to say. Regarding that particular field you point to in the image, refer to the detailed description for it here: Trade Activity Log: Trades Fields Descriptions We cannot provide further help. You have the documentation and you have the underlying recorded high /low during position data , and you know what you did and you know what the price action was, to do all the analysis that you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-06 08:18:34
[2021-08-09 14:57:12] |
The Max open loss on the log with the arowed row shows a value of 162.5, which is 12 ticks for the ES. Take a look at the chart, do you see the trade ever being in such a loss on that chart? |
