Date/Time: Fri, 28 Feb 2025 04:56:28 +0000
Denali, routing....
View Count: 548
[2021-08-05 13:17:52] |
BenjFlame - Posts: 335 |
Hello, I subscribed to Denali data. My broker is AMP currently enabled with CQG. 1) Is there a way to use Sierrachart routing with my AMP account so I would use data and routing from sierra, and AMP only as broker. 2) If not is it possible to use sierrachart Denali for data, and amp/cqg for routing at the same time. If yes please advise. 3) Can you please check if my setup is correctly connected with live trading account so I can receive the live data with proper CME fees? Thank you |
[2021-08-05 15:03:39] |
John - SC Support - Posts: 38259 |
1. No, this is not possible, as AMP does not support the Sierra Chart Order Routing Service. 2. Yes, you should already be setup for this. 3. For some reason it is not, but it looks like you are connected to your CQG account. Be sure you are fully connected to your CQG account and you are not having issues with that connection. Check your Message Log for any errors with the connection. You can see the date of your verification in this section: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 20:56:33] |
Ok now i'm verified until: Verified Till: 2021-09-04 so I guess it's ok.
[2021-08-06 13:36:30] |
Just keep in mind that if you are not going to stay connected to your CQG account that you will need to connect to that account prior to September 4 in order to verify your account for another month. Refer to he instructions here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
