Date/Time: Fri, 28 Feb 2025 05:00:31 +0000
11 - Advanced + Denali Data Feed
View Count: 447
[2021-08-05 10:31:50] |
User624560 - Posts: 4 |
I have 11 - Advanced + Denali Data Feed (For 6 Months) but i can't have the Denali exchange data feed service, what should i do? my user is EZUser102 |
![]() Attachment Deleted. |
[2021-08-05 14:32:00] |
John - SC Support - Posts: 38259 |
You have not gone through all of the Setup Instructions for the Denali Exchange Data Feed. You need to go through all the steps as outlined at the following link for the CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are wanting to setup data for the EUREX or CFE, then those instructions are on the same page as above. Just scroll to the top to find the specific instructions for those exchanges. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
