Date/Time: Fri, 28 Feb 2025 04:32:42 +0000
Additional Symbol not showing correct value
View Count: 446
[2021-08-04 17:14:28]
DayTraderEsad - Posts: 121
I have a chartbook where I used the "Add Additional Symbol" study to the chart. When the additional symbol is added the values are off and I tried changing the value format in the study settings and the issue still remains. For example I have my main chart as RTY and the values are correct. Now when I add the ES as the additional symbol in region 2 - the value shows 440350 instead of 4404.50. Can that be fixed for someone who has the TT routing/Denali service? Also attached two screenshots as well.
imagesymbol.PNG / V - Attached On 2021-08-04 17:10:02 UTC - Size: 62.09 KB - 171 views
imagesymbol1.PNG / V - Attached On 2021-08-04 17:10:06 UTC - Size: 30.5 KB - 181 views
[2021-08-05 17:43:18]
We apologize for the delay. You need to set a Price Multiplier in the Add Additional Symbol study for that symbol and set it to .01.
Documentation:
Add Additional Symbol: Inputs
