Date/Time: Thu, 19 Sep 2024 02:03:52 +0000
Export settings to new computer
View Count: 3094
[2014-03-20 11:51:23] |
Demi1201 - Posts: 68 |
Hi, I have to migrate to a new computer and would like to transfer my existing SC settings, study collections etc. How is that accomplished? Thank you, Dem |
[2014-03-20 12:37:59] |
I have saved my Chartbook.cht to Sierrachart/Data and copied it to the new computer. Works like a charm. So, if this is the appropriate method I think I've found it. Please let me know if I did something that might not work in the future. I'm migrating to a Windows8 computer. Installed SC in C/Sierrachart (not in Program Files). OK, thanks for some supervision and eventual advise. Dem |
[2014-03-20 12:41:17] |
Graham - Posts: 44 |
Here's a walkthrough.... http://www.sierrachart.com/index.php?l=doc/helpdetails15.html |
[2014-03-20 19:13:06] |
You did everything correctly. Help topic 15 given in the prior post is the relevant documentation for this.
