Date/Time: Fri, 28 Feb 2025 05:02:16 +0000
How to connect my AMP trading account to SC with Denali Data Fee
View Count: 464
[2021-08-04 16:12:25]
User833646 - Posts: 3
Hi Sierra Chat support team,
Would be most grateful if you could kindly help me out to connect my AMP trading account to SC so that I can start trading live using Sierra Chart.
I am not on CQG system.
Thx.
FC
[2021-08-04 18:10:29]
John - SC Support - Posts: 38259
If you are NOT using CQG, then you should be using Rithmic with AMP. If you are setup with TT with AMP, then you can not use Sierra Chart to send orders.
If you are setup with Rithmic, then follow these instructions to connect to your Sierra Chart:
Rithmic Trading Platform Service: Setup Instructions
[2021-08-05 04:40:21]
Hi Sierra Chart Team,
Thx for your reply.
I choice not to be using CQG with AMP because there are latest announcement in the Sierra Chart message board that there are issues with CQG and advise not to connect using CQG.
Please kindly update.
Thx.
FC
[2021-08-05 14:17:47]
We have issues with both CQG and Rithmic data. In terms of the Order Routing, they are fine, although there are some restrictions which you can find in our documentation related to each interface.
We really recommend using our data feeds in order to ensure that you do not have any issues and your experience with Sierra Chart is the best it can be. Refer to the following information:
Real-Time Exchange Data Feeds Available From Sierra Chart
