Date/Time: Fri, 28 Feb 2025 05:02:56 +0000
live trading account
View Count: 394
[2021-08-04 16:12:01] |
MR17 - Posts: 34 |
Hi ! i am actually sim trade and used a sim account ! but i want to live trade now and i do not see on the list of trade account available my live account ? i just see as an available account: - sim1 -training17 (which by the way seems not to work and i do not why ?) Thanx a lot for your return Mamy |
[2021-08-04 16:54:23] |
John - SC Support - Posts: 38259 |
You need to set your File >> Data/Trade Service Settings for the trading service that you are using. We see that you are setup with the Sierra Chart Order Routing service through Stage 5. If that is correct, then you would need to go through the following instructions starting at #9 to get your settings correct for this service: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
