Date/Time: Fri, 28 Feb 2025 04:53:47 +0000
Chartbook time charts are ahead
View Count: 511
[2021-08-04 13:59:40] |
hr719 - Posts: 25 |
So, one of my chartbooks all the time charts in it are one min ahead. My other chartbooks are all correct time. Even trading view is correct time on 5 min charts, but when I look at this one certain one, it is one min aheads. My windows time is correct, Date time from server is checked under global settings. The time is correct on Sierracharts bar. It is only in these one chartbook that the time is wrong. What setting did I mess up?
[2021-08-04 16:29:13] |
John - SC Support - Posts: 38259 |
Please attach the Chartbook to this thread so we can take a look by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 00:07:45] |
hr719 - Posts: 25 |
attached
[2021-08-05 07:20:18] |
How exactly do you come to this conclusion:? So, one of my chartbooks all the time charts in it are one min ahead.
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 13:37:25] |
Your Session Times are incorrect. Your Primary Session is fine, but your Evening Session starts at 16:59:00, but it should be 17:00:00 and the end time needs to be 08:29:59.
