Date/Time: Fri, 28 Feb 2025 04:43:37 +0000
Package 11 with Denali - EUREX doesn't work
View Count: 545
[2021-08-04 13:33:48]
User330092 - Posts: 9
I was using package 11 through all JULY as a "test period". Everything works fine.
I am Transact user so what i did today:
1.OPT OUT from receiving EUREX data from TRansact
2. Renew 11package with DENALI
3. Open platform as always -> no quatation for Eurex.
4. Ofcourse i want my trades go through Transact as my broker.
How can i fix this?
Best Regards
Date Time Of Last Edit: 2021-08-04 13:36:25
[2021-08-04 13:44:22]
John - SC Support - Posts: 38259
You did not go through all of the setup for the Denali Exchange Data Feed. Follow all of the instructions here:
https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX
[2021-08-04 14:08:47]
What is the exact name of broker i should type in ( I use Transact) but as i understand this might not be a proper name. Please navigate me through this step.
Date Time Of Last Edit: 2021-08-04 14:09:45
imageScreenshot_1.png / V - Attached On 2021-08-04 14:09:41 UTC - Size: 12.72 KB - 163 views
[2021-08-04 16:09:23]
You will type in "TransAct" (no quotes) for the Broker there.
[2021-08-04 17:04:40]
Field Signed -> should be My full name or just login used as subscriber?
[2021-08-04 18:20:01]
Your proper full given name.
