Date/Time: Fri, 28 Feb 2025 05:09:37 +0000
My TPO chart does not have a minimize / maximize / close bar
View Count: 488
[2021-08-04 11:07:18] |
User306113 - Posts: 3 |
Hello, I am not able to see the maximize or minimize buttons for my chart window. Is there any way to get it back? |
Attachment Deleted. |
[2021-08-04 14:50:11] |
John - SC Support - Posts: 38259 |
Select Chart >> Show Title Bar. Refer to the following for more information: Chart Menu: Show Title Bar (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-08-05 05:11:35] |
Thank you very much for clarifying my issue. I had a hard time locating what option may have been able to return the bar.
