Date/Time: Mon, 25 Nov 2024 22:29:28 +0000
6A chart can't load properly
View Count: 1356
[2014-03-20 10:52:57] |
JingIt - Posts: 44 |
http://screencast.com/t/nIWlbCEWn I did create new chartbook but my chart can't load properly, it appear a single line then candle stick bar up like the screenshot. I dont have any study in chart. Please help |
[2014-03-20 15:11:04] |
Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You will then need to apply the symbol settings to that chart following these instructions: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
