Date/Time: Thu, 08 Oct 2026 23:29:04 +0000
Mbo Presentation
View Count: 1216
[2021-08-04 02:36:15]
User529087 - Posts: 25
Hi
I followed the guideline to put the MBO on my DOM.
And have something different than in the example, how can i get it the same with a clear background, and presentation.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53410
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=53411
Date Time Of Last Edit: 2021-08-04 04:43:03
[2021-08-04 05:34:17]
Sierra_Chart Engineering - Posts: 25108
To widen the market by order data columns, refer to:
Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns)
To prevent overlapping numbers you need to decrease the scale range. Refer to:
The Chart DOM Scale
[2021-08-05 02:11:09]
Thank you so I did that, now:
1. How do I remove the red, green background colors for the MBO?
2. How do I change the colors of the characters?
3. See attachment:
On the 4400 level I have the following on the MBO BID (green color).See picture
40,8,8,8,5.
Is this 5 orders?
Is the first one in the queue of 40 lots? or is the 5 lots order?
I thought you only displayed order of 10 lots or above? why I see less? Is there a filter or setting for the MBO itself?
And finally If i want to have this information on a regular dedicated dom without any charts to it, how would I proceed?
Thank you very much for the support your offering
imagembo3.PNG / V - Attached On 2021-08-05 02:02:33 UTC - Size: 55.5 KB - 326 views
[2021-08-05 14:09:59]
John - SC Support - Posts: 48161
1/2. Refer to the 4 settings starting here:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Bid Market Orders Background
3.
40,8,8,8,5.
Is this 5 orders?
Yes, that is 5 orders.
The order of the data is defined by how you have the column aligned. Refer to the information here:
Market By Order Data: Queue Ordering and Alignment
We need to update the documentation, but the number has been lowered to 4.
You can set the level below which you will not see the MBO data. This is done on a per symbol basis and is controlled in the Symbol Settings. Refer to the following:
Market By Order Data: Adjusting Minimum Quantity to Display for Market by Order Data
Just follow the instructions but for the Trade DOM. Refer to the following:
Market By Order Data: Step-by-Step Instructions
