Date/Time: Fri, 28 Feb 2025 04:20:30 +0000
Want to Activate Denali data feed
View Count: 784
[2021-08-02 16:16:20]
ruby_kinetix - Posts: 24
Hi there, I already have a trading account with AMP Futures. and already have CQG login.
now I need Denali data feed, Full CME Group (CME, CBOT, COMEX, NYMEX) + Market Depth. Where shall i go from here ?
I am not sure if I want MBO data or need. I like to try it .
Shall I change my service to 11 or 12 (I want to go per 6 months) now or else for trial ?
[2021-08-02 17:26:30]
John - SC Support - Posts: 38259
Just follow these Setup Instructions. There is a section in them for changing your package, so you will take care of that at the appropriate time in the setup:
[2021-08-03 16:26:54]
Sierra Chart - Max - Posts: 5793
From user:
I already follow as instructed, but I still get delayed data , did I miss something here ?
and is there any tutorial to set the MBO and Market Depth?
Sierra Chart Support
[2021-08-03 17:19:52]
You have signed up for the Non-Professional CME exchanges, which means that you need to connect to your live, funded futures trading account at the beginning of each month to qualify for the lower-priced exchange fees. You have not connected to your trading account yet this month. Refer to the following:
Not specifically. But for the MBO data, refer to the following which gives you the information for how to view the data:
Market By Order Data: Step-by-Step Instructions
For the Market Depth, it is a matter of having the correct columns displayed in the DOM. Refer to the following:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
[2021-08-04 12:10:03]
hi there, I am not sure exactly why i can't get live data yet. can you please specify what I need to do here? I believe I signed everything. about connecting to my AMP future account, I am not sure how to do it. I already follow everting on the link.. I need your help here. please.
thank you .
imageScreen Shot 2021-08-04 at 7.03.21 PM.png / V - Attached On 2021-08-04 12:07:04 UTC - Size: 2.19 MB - 195 views
imageScreen Shot 2021-08-04 at 7.05.57 PM.png / V - Attached On 2021-08-04 12:07:16 UTC - Size: 2.43 MB - 212 views
[2021-08-04 14:59:32]
You need to setup your Sierra Chart software to connect to your CQG account. To do this, follow these instructions:
CQG Trading Platform Service: Setup Instructions
