Date/Time: Tue, 26 Nov 2024 00:34:21 +0000
range bars
View Count: 1127
[2014-03-20 01:13:11] |
User78867 - Posts: 2 |
Hello, I am having trouble creating 2 point range bars. Can you give me any pointers? Thanks |
[2014-03-20 01:24:16] |
For what symbol?
[2014-03-20 10:36:09] |
I am looking at the euro USD currency pair, but would also like to have this range bars for AAPL and DIA equities but I haven't figured out how to change symbols or if equities are available. thanks Lloyd |
[2014-03-20 12:07:02] |
Graham - Posts: 44 |
Lloyd, Range bar size is related to the tick size for the instrument. For example, if you wanted a 2 point range for the emini (ES symbol) the range bar setting should be 8 as the tick size is .25 You can change symbol by pressing F5 is you have a chart open or by selecting File, Find Symbol |
[2014-03-21 21:28:34] |
Here is the documentation for Range bars: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-21 21:29:56] |
Stock data is supported. Did you need real-time data for stocks? Or just historical data.
