Date/Time: Wed, 23 Sep 2026 12:22:37 +0000
NYSE Fang Index - Interactive Brokers
View Count: 807
| [2021-08-01 12:29:16] |
| User417302 - Posts: 70 |
Can you please add the NYSE Fang + index? Or if it does exist what is the symbol, as I could not find it and I have already updated the symbols from the server. It's a cash index. Thanks, |
| [2021-08-02 08:52:34] |
You need to determine what the symbol is and manually enter it. Refer to: Interactive Brokers Symbols Once you find out what the symbol is, let us know and we can add it. We do not know what symbol they use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-02 08:52:53
| [2021-08-02 15:29:07] |
Are you referring to this? Here is the info that I got from IB.
Attachment Deleted. |
| [2021-08-02 15:46:28] |
Nevermind, I figured it out and was able to add the symbol on my own. But thank you anyway.
