Date/Time: Fri, 28 Feb 2025 09:20:00 +0000
Customizing Rectangle Chart Drawing tool
View Count: 1392
[2021-07-29 15:33:49] |
countryboy92 - Posts: 91 |
I have saved a rectangle button in my custom control bar and formatted the color and line size. After drawing a rectangle, I go to chart drawing properties and choose "show price labels" which puts shows the high and low price labels. I cannot figure out how to set "show price labels" as my default for each time I draw a triangle.
[2021-08-12 05:59:34] |
We will look into this.
[2021-08-13 14:17:17] |
We looked into this, there is not support for price labels on Triangle Chart Drawings.
[2021-08-14 00:20:39] |
User90125 - Posts: 715 |
Could this be added as a future [Feature Request] ? Thanks. |
[2021-08-14 07:53:17] |
Yes we will see about adding support for this.
