Date/Time: Fri, 28 Feb 2025 04:51:17 +0000
DTC related issue when modifying a buy limit order
View Count: 680
[2021-07-27 19:47:27] |
onnb - Posts: 662 |
The following happens when using the "DTC Service" SC is connected to a custom dtc bridge we are working on. Trade Simulation Mode is off Reproduce Place a BUY limit order away from the market => observe all good, order is submitted and is updated on SC fine (we can see it on the chart). Then modify the limit order on the chart (still away from the market). We see SC sending cancel to the existing order and then sending a SELL limit order. This happens only with BUY limit orders. It does not happen with SELL limit orders. Any ideas why this might happen? Date Time Of Last Edit: 2021-07-27 19:49:11
[2021-07-27 22:30:03] |
Sierra_Chart Engineering - Posts: 18594 |
Make sure this is set to 1 in the in the DTC logon response: OrderCancelReplaceSupported However, what we do not understand is why this does not happen consistently with buy and sell orders, and why the side is changing. That is of major concern. But we do not really know all of the surrounding details. Provide us the lines in the Trade Activity Log, when you have this problem with the order modification: Trade Activity Log: Providing Trade Activity Log Data Lines to Support We need to look at this and understand why there is an issue with the side and why there is not consistent behavior on both the buy/sell side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-27 22:30:43
[2021-07-27 23:26:02] |
onnb - Posts: 662 |
Its probably something I'm doing wrong. Attached is the TradeActivityLog |
[2021-08-04 07:24:28] |
We see the problem. As we suspected, when your server indicated the order is canceled it indicates the side is now a sell when it was previously a buy: Orders 2021-07-27 12:29:33.729108 XBTUSD DTC Service order update (Canceled) 8312 ec3ee6c6-1732-4f73-8d3c-11d3363eafa9 Limit Sell Cancel/Replace DtcAcc Open 0.00 8312.96609 Day
So it is the responses from your server, related to their order fields which is the source of the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-04 07:26:00
