Date/Time: Wed, 09 Sep 2026 14:20:35 +0000
Best data feed for charting and analysis. CQG discontinued support
View Count: 967
[2021-07-27 15:14:31]
User583218 - Posts: 1
Hello sorry if this is redundant. I searched and didnt find what i was looking for. I am trying to set up my trading accounts and need some insight.
I have tradeovate account to trade with and using jigsaw DOM to make trades. I want sierra for charting and analysis only and was looking at advanced package but need data feed for it.
My buddies are using tradeovate CQG feed but read post about CQG support being discontinued in September. I want the easiest and best way to go about this. Does Sierra data feed have the same speed and market depth as tradeovate?
Which is the better way?
Most likely be doing CME only at first.
[2021-07-27 15:59:10]
John - SC Support - Posts: 47810
The main thing you need to be aware of with regards to the CME Group data is that you need to have a live, funded, futures trading account in order to qualify for the lower-priced non-professional exchange fees. And you need to able to connect to that account at least once a month with your Sierra Chart in order to continue to verify that you have the account. For more information, refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
If you can connect to your CQG account with Tradeovate once a month, then that will suffice to satisfy the CME Group.
Definitely the Denali Exchange Data Feed will give you the best data available for Sierra Chart. It has at least the same speed (if not faster) than other feeds and has 1400 levels of Market Depth data for the CME Group instruments. For more information, refer to the following:
