Date/Time: Mon, 25 Nov 2024 22:47:51 +0000
NQ-201406-GLOBEX
View Count: 1005
[2014-03-19 17:30:38] |
User39772 - Posts: 311 |
Draw DOM Graph on Chart does not work with this future. It worked with the previous future and other futures. DOM at broker is ok. I use IB feed. |
[2014-03-19 17:49:22] |
See if there is market depth data available by selecting File >> Open Market Depth Window. Also refer to this section here: https://www.sierrachart.com/index.php?l=doc/IB.php#MarketDepth Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
