Date/Time: Tue, 29 Sep 2026 03:51:17 +0000
Funders
View Count: 988
| [2021-07-26 18:37:11] |
| Deltareversal - Posts: 63 |
Tt is not clear to me if it is possible to use Sierra through one of these funders (https://yyy3.rithmic.com/?page_id=15) Can you give me a concrete answer ? Thanks |
| [2021-07-26 19:28:36] |
| John - SC Support - Posts: 48044 |
Rithmic has put out their new interface for Sierra Chart, therefore it is now possible to use Sierra Chart with these Trading Evaluators using Rithmic. You just have to be on Package 10 or higher in order to use Rithmic with Sierra Chart.
| [2021-07-30 15:50:55] |
These funders provide Rithmic as a data feed. If I wanted to use Denali what should I do: Activate Denali real time, while for Exchange (CME / EUREX)? Rithmic data feed when historical tick by tick has? == A |
| [2021-07-30 17:26:28] |
These trading evaluators cannot yet be used with the new Rithmic connection until Rithmic allows that. So that is not yet ready. We hope that will be soon. You need to activate the exchanges from here for the Denali data feed: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed However it will not make sense in your case to activate the CME data if you do not have a live funded trading account. These trading evaluator accounts do not apply. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-07-30 19:05:26] |
I am Sorry above John "Posts: 9538" tell is possible to use Rithmic interface for Sierra Chart.. I do not understand. If you can learn ? A. |
| [2021-08-02 14:28:09] |
I made a mistake. I figured Rithmic had setup the ability, but as posted by Sierra Chart Engineering, apparently the work to fully support this has not occurred.
