Date/Time: Mon, 25 Nov 2024 22:24:19 +0000
is OEC connection back to being reliable with latest SC version???
View Count: 1901
[2014-03-19 15:32:51] |
snillumat - Posts: 29 |
Has anyone using OEC upgraded SC back to latest version in the last day or two? I'm just wondering if any actual users have tested and can verify that the connection problems have been resolved. Thanks
[2014-03-19 16:19:55] |
From what we see, the problem has been resolved by OEC. One problem they quietly resolved and a supposed hardware problem was resolved by them.
[2014-03-19 18:44:45] |
NRGTrader - Posts: 351 |
OEC connection has been working fine here using version 1107 or greater for over one week here.
