Date/Time: Tue, 04 Nov 2025 18:08:30 +0000
Left click drawings
View Count: 510
[2021-07-26 02:27:09]
User575399 - Posts: 333
Is it possible to move extended rectangles using just the left click then drag an exsisting rectangle? I use this for zones a lot throughout the day. I tried changing the tool settings stated on previous message board posts and still nothing .Thanks!
Date Time Of Last Edit: 2021-07-26 02:27:56
[2021-07-26 03:51:39]
You need to use this option:
Chart Drawing Tools: Support Drag For Chart Drawing Creation/Modification (Global Settings >> Tool Settings >> General >> Tool Options)
[2021-07-26 04:12:03]
Yeah I tried that still nothing. Any other ideas?
[2021-07-26 17:34:17]
John - SC Support - Posts: 42761
Be aware of where you select within the Rectangle to drag it. Refer to the following that shows the "Zones" for Adjusting versus Moving a highlight drawing:
Chart Drawing Tools: Adjusting Rectangle, Extending Rectangle, Ellipse Drawings
