Date/Time: Tue, 26 Nov 2024 01:43:30 +0000
Line at a non defined level
View Count: 995
[2014-03-19 15:03:25] |
Dom7364 - Posts: 257 |
How can I set up a horizontal line at a non defined level/moving and evolving level, such as price for example?
[2014-03-19 15:43:16] |
Sierra Chart - Max - Posts: 5731 |
To display a line on the current price you can use the Current Price Line study: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s123 For arbitrary Horizontal Lines, you can use the Horizontal Line tool here: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#VerticalandHorizontalLines Sierra Chart Support |
[2014-03-26 08:56:15] |
Can I display a line which has nothing to do with the price, and that I don't have to draw myself? Same as there is a Current price line which automatically detects current price and adds a line, can I do the same for any given study/part of a study: For example, WVAP, VWAP SD',etc?
